firefighter54 Newbie
Posted: Mar 14 2015 at 5:54pm | IP Logged
Ok so im new to this site and to a Frontier.
I have a 2008 Frontier SE.
My question is this, when I put it in 4hi or 4low the 4WD light blinks. Is it supposed to do that or should it stay lit up when its in 4wd? I can hear it click into 4hi and 4lo when I turn the switch. any help would be grateful.
Also when I bought the truck they put new breaks and rotors on the front. My ABS and SLIP light keeps coming on. and they said that I had a lil noise coming from the front ps frontend. They say its the bearing, and that is whats causing the ABS and the SLIP light to come on. would this be causing the 4WD light to blink?
Posted: Mar 15 2015 at 5:25pm | IP Logged
If the ABS lite is on indicating a problem, the 4WD will
not engage. The bad bearing should be replaced which
includes the wheel sensor. The 4WD indicator does not blink
when operating correctly.
