Ran-D Newbie
Posted: Jan 15 2015 at 10:29pm | IP Logged
Hope you guys can help. I have a pretty bad leak (about half to a quart a
week) coming from the passenger side of the engine around the oil
filter area. I already changed the rear and front oil seals and oil pan
gasket as well as changing oil filter brands. I pressured washed the
undercarriage and that side of the engine is always wet with oil and
rest is nice and dry.
Is there an external oil line that could be leaking or any ideas?
Thanks in advance and Aloha!
Posted: Jan 16 2015 at 6:09pm | IP Logged
How about the oil pressure switch?
ASTF26 Newbie
Posted: Feb 03 2015 at 1:17am | IP Logged
+1 on checking to see if the oil pressure switch is leaking. A leak that bad is generally caused by oil being leaked from a pressure source.
