PaperBoy Newbie
Posted: Oct 22 2013 at 10:40am | IP Logged
I upgraded the door speakers in my 09 Frontier King Cab. While researching this upgrade, I found a lot of discrepancies regarding the “Wire Colors” for each of the four speakers. Unfortunately, no one provides an adapter plug for the 05-13 Frontier. You will have to cut the plugs off and wire in the new speakers. Nissan doesn’t show a polarity mark on the factory speakers. Here’s a little trick you can do to determine the Positive (+) speaker wire: Remove the factory speaker, and hook a battery (1.5 V AA, or C, D) whatever you got handy across the speaker terminals. When the Pos + Batt post is connected to the Pos + speaker terminal, the speaker cone will move “Outward”. If you hook it up the other way, the cone will move “Inward”.
__________________ 1998 Frontier XE
2009 Frontier. SE
Posted: Oct 22 2013 at 10:03pm | IP Logged
Great... I didn't know that...Thanks!
Have a good one.. Don S..
