Subject Topic: Spark knock on a 02 S/C Post ReplyPost New Topic
scavenger
U.S. - Georgia
Posted: May 08 2012 at 11:28pm | IP Logged Quote scavenger
i have replaced my knock sensor,belts,spark plugs,wires and air filter but for
some reason im still going into spark knock there are no codes being thrown
no check engine and no codes without check engine light coming on. So my
question is wha am i not seeing? I havent checked the timing yet im not sure
but i might have skipped a tooth on my timing belt. I only put premium gas
that has no ethanol in it and is 93 octane. Basically when im driving i can see
that im getting 7.5 lbs of boost then out of no where it drops to 3 lbs i know
this cause i have a boost gauge. i have noticed that it will drop when im in
third gear or in second when im at 3500 rpm im so pissed I NEED HELP!!!!!!!!!
im really close to taking it to a nissan dealership and paying them to do a
diagnostic test on it for like $90 an hour but i know it has to be something
simple that im not seeing!
2002 Frontier 4x4 crew cab S/C
MECP certified auto tech
Back to Top View scavenger's Profile Search for other posts by scavenger
Posted: May 11 2012 at 7:13pm | IP Logged Quote frontierguy
I would recheck the TB.
scavenger
U.S. - Georgia
Posted: May 11 2012 at 10:48pm | IP Logged Quote scavenger
Define TB do you mean timing belt or throttle body?
Posted: May 14 2012 at 8:04pm | IP Logged Quote frontierguy
timing belt
scavenger
U.S. - Georgia
Posted: May 17 2012 at 10:27am | IP Logged Quote scavenger
if i shipped a tooth wouldnt i have some sort of check engine light or code pop up for me to check also would it be idling different or sputtering?
Posted: May 18 2012 at 8:42pm | IP Logged Quote frontierguy
NO, no and no. Well , maybe! It would depend on which cam
is off in relation to the crank. If the crank and left cam
had the correct count of teeth between them, there would be
no DTC, there are not cam sensors for each cam, only the
left one which is the distributor.Are you sure the drop in
boost is not normal for this engine at that RPM? If you are
getting spark knock, it would retard the timing.
davidjbrady
Posted: May 19 2012 at 12:14pm | IP Logged Quote davidjbrady
On a related matter, my neighbor had a 90's Infinity, with the VG motor, and there was a knock upon acceleration. You could rev it under no load, it would knock. It also knocked upon acceleration from a stop light. He too had no check engine light indications. It had 52K miles on it, he paid the dealer to diagnose it, he was told to have the timing belt changed. He protested since it did not call for the belt to be replaced at this mileage, but dealer countered and said the powertrain is fine, not broken, therefore no warranty repair is needed.
Dealer did say that if the belt caused engine failure, then yes, warranty would cover a new engine.
He ended up having the belt replaced, and the sound was gone, ended up keeping the car and had no issues for years.
( this occurrence happened about 15 years ago)
08 Frontier CC, 4X4, LWB
davidjbrady
Posted: May 19 2012 at 12:25pm | IP Logged Quote davidjbrady
One more thing I forgot to mention I had a 94 pathfinder with the VG motor I decided to do the timing belt when the water pump leaked and did not realize that I was off a tooth when putting the belt back on until I had it smogged months later, the timing was off and it would not pass.
I did not want to mess with the distributor to adjust timing since it was never changed (the timing) since the day I bought it. I took the front cover off and the right cam was off a tooth, I had no symptoms.. strange....
scavenger
U.S. - Georgia
Posted: May 20 2012 at 12:49am | IP Logged Quote scavenger
Thank you both I am now going to look into the timing and post my
results I have pics of when I took the supercharger off and replaced the
knock sensor and now this I will try and take pics of this as well to post
thanks for the advice
