Posted: Mar 21 2012 at 8:27pm | IP Logged
The VCV is attached to the canister above the spare tire.
Most likely it will also need the canister due to the fact
that the canister cracks at the point where the nuts are
located, causing a "very small leak" code. Usually the
bolts won't come out either due to rust.
