Subject Topic: Clutch Noise Post ReplyPost New Topic
eitydeuce
U.S. - Nevada
Posted: Mar 14 2012 at 8:34pm | IP Logged Quote eitydeuce
I recently replaced the clutch on my 2000 Frontier with a 2.4 ,manual trans. After a few months a noise started when i would shift gears. I dont think its a grinding noise such as a bad gear but more like the clutch doesnt fully engage.  It was a clutch kit from NAPA auto parts which came recommended to me. I tried bleeding the slave cylinder and checking the hydraulics for leaks. Any guesses?
Back to Top View eitydeuce's Profile Search for other posts by eitydeuce
Posted: Mar 15 2012 at 7:03pm | IP Logged Quote frontierguy
Do you mean the clutch doesn't fully dis-engage??? How is
it going into gear when the vehicle is stopped? How much
"free-play" is at the top of the clutch pedal?
eitydeuce
U.S. - Nevada
Posted: Apr 03 2012 at 8:51pm | IP Logged Quote eitydeuce
It seams as though the clutch does not fully disengage while shifting gears. At a a stop the gears go in ok. When i bleed the clutch cylinder the pedal gets stuck all the way down and i have to manually lift it to pump the pedal again. As far as freeplay it doesnt seem to have too much.
Posted: Apr 04 2012 at 8:16pm | IP Logged Quote frontierguy
Follow the hydraulic line from the master cyl. to the slave
cyl. Somewhere on the firewall there should be a dampner
with a bleeder on it. Bleed this, then the slave cyl.
