Subject Topic: 2007 Thermostat Post ReplyPost New Topic
pipewrench
Posted: Feb 29 2012 at 5:29pm | IP Logged Quote pipewrench
Where is the thermostat located on a 2007 Frontier SE and how do I change it????
Back to Top View pipewrench's Profile Search for other posts by pipewrench
Posted: Feb 29 2012 at 7:18pm | IP Logged Quote frontierguy
The thermostat/outlet assy. is located on the front of the
timing chain cover drivers side of the engine. Best if you
get a Genuine Nissan replacement. As far as replacing it,
one bolt at a time. In all honesty, if you don't know where
it is or how to change it, you should leave it to a Nissan
dealer due to the fact of the refill procedure for the
coolant system and special vac. tool needed for the
procedure.
davidjbrady
Posted: Feb 29 2012 at 10:25pm | IP Logged Quote davidjbrady
I was told that you should elevate the front of the truck when putting coolant in it, air in the system would rise to the highest point, which would be the RAD if truck elevated.
Is that true?
08 Frontier CC, 4X4, LWB
Posted: Mar 01 2012 at 7:42pm | IP Logged Quote frontierguy
davidjbrady, on the modern day Nissan, it is very difficult
to properly refill the system w/o the proper vac. refill
tool.
