Subject Topic: 2005 Frontier XE rattle/vibr at low idle Post ReplyPost New Topic
UnkleJethro
Posted: Feb 22 2012 at 11:01pm | IP Logged Quote UnkleJethro
Greetings all!
I've got a 2005 Frontier XE (4 cyl) that I purchased new.  Been an excellent truck so far (just turned 90k miles.)
About two years ago I noticed a rattle/vibration from the plastic breather box on top of the engine when the motor is at low idle (in drive) around 700 rpm.  When the motor revs up the vibration/rattle goes away but when the engine settles back down like at a red light, it starts rattling again.
Dealership checked it out, said it wasn't doing any damage and it wasn't covered by the warranty (when less than 60k) so I held off of fixing it...it was just an inconvenience.
It's still annoying but I can't remember what they said the problem was... some kind of bushing underneath the breather box perhaps?  Sounds the the plastic breather box is vibrating on the valve cover.
Any ideas?  Any ideas on how I can fix this by maybe replacing a rubber bushing, etc?
Thanks,
Unkle Jethro.
Back to Top View UnkleJethro's Profile Search for other posts by UnkleJethro
Posted: Feb 23 2012 at 7:27pm | IP Logged Quote frontierguy
Have you removed the breather box to check the mounts?
Don't see many 4 cyls.
