droopydawg Newbie
Posted: Feb 19 2012 at 4:01pm | IP Logged
05, CC, SE 4x4. This should be one of the easiest things to accomplish.
Didnt see adjusted under vehicle, so I assume that are on the E-brake
assembly attached to handle.
right?
How do I gain access under the plastic interior trim pieces? I dont see any
screws.
__________________ Drew Mobley
Lake Forest, Illinoying
05 CC SE 4x4 V6 6spd man.
Posted: Feb 19 2012 at 4:49pm | IP Logged
Remove the rear wheels, you will find a rubber plug, remove
it, rotate rotor to access parking brake adjuster wheel.
You might want to remove rotor to inspect condition of
shoes first.
droopydawg Newbie
Posted: Feb 19 2012 at 6:08pm | IP Logged
does it matter that I have rear disc brakes and not drums?...or do all
reasonably current frontiers also have all wheel disc brakes?
droopydawg Newbie
Posted: Feb 19 2012 at 6:16pm | IP Logged
Ahhhh, nevermind. I found a pdf version of the PB section of manual. Now it
makes sense. thank you
http://vpnavy01.ipower.com/nissan_pdf/2005_frontier_section_ PB.pdf
