abystander2 Newbie
![Newbie](forum_images/1_star_rating.gif)
![Avatar](avatars/waveform.jpg)
Posted: Dec 30 2011 at 9:49pm | IP Logged
I am trying to install a new radio in 2000 Frontier. It
worked fine when the wires were just twisted together,
however, once I soldered them, it quit working. Now when I
try to put the factory radio back in it won't turn on. The
back-lights turn on with the headlights, but the display
doesn't show anything.
Any advice for installing the new radio would be great, but
my main concern is getting the old one working again.
Thanks for any help you can give.
__________________ '00 Nissan Frontier SE
jgreenjr Senior Member
![Senior Member](forum_images/3_star_rating.gif)
![Avatar](http://www.nissanfrontier.org/mgallery/jgreenjr/2009-10-03_201847_HPIM0327.JPG)
Posted: Dec 31 2011 at 10:17am | IP Logged
Thanks for any help you can give. |
did you unplug the radio before you soldered them? i do that for safety so i wont be damage radios ! just a thuoght. i have no problem with install them my self !![](smileys/smiley1.gif)
__________________ Jackie
A Proud owner of
2003 Nissan Frontier XE
4 cyl.
4x2
auto.
KA24DE
Stereo:Kenwood KDC BT648U
Ham radio since 2001 N4MJG
Tullahoma Tenn
abystander2 Newbie
Posted: Dec 31 2011 at 2:11pm | IP Logged
I did
Posted: Jan 02 2012 at 11:37am | IP Logged
Hmmmm that is weird never see one do that before ! before i put everything back on i make sure it works ! i been doing this for long time never have any problem plus i disconected from battery as well. safely wise ! i hope you can fiqure it out. let us know !![](smileys/smiley2.gif)
A Proud owner of
4 cyl.
4x2
auto.
KA24DE
Tullahoma Tenn
Posted: Jan 02 2012 at 7:28pm | IP Logged
Check the fuses and correct wiring?????
abystander2 Newbie
Posted: Jan 03 2012 at 4:45pm | IP Logged
wiring????? |
Fuses are good. I'm pretty sure I have the correct wiring,
I mean it worked before I soldered it...
Posted: Jan 03 2012 at 4:52pm | IP Logged
abystander2 wrote:
frontierguy wrote:
Check the fuses
and correct
wiring????? |
check the ground and make sure they are connected
good !double check all wires right ones in the right
place.....
A Proud owner of
4 cyl.
4x2
auto.
KA24DE
Tullahoma Tenn
abystander2 Newbie
Posted: Jan 28 2012 at 10:02pm | IP Logged
Well I feel really dumb... I checked only checked the fuses
in the cab not realizing there was another under the hood.
Turns out the audio fuse was tripped. Replaced it and
everything works great! Thanks for all your help!!
