Posted: May 01 2006 at 2:36pm | IP Logged
I wanted to let you know I fixed the problem. I had to replace the distributor. It worked out good. I decided to put some money back into my frontier instead of getting a new one. Im replacing all mechanical parts that need to be replaced. I have 125,000 miles on her. Im also adding a 3" supension lift with 31x10.5 tires. I got the headliner replaced cleaned the inside and replaced the cd player. The trucks starting to look good. I will post some pics when it's done. I appreciate the feed back.
