Subject Topic: Frontier NisMo - OBD 2 error code P0345 Post ReplyPost New Topic
Geno
Posted: Aug 11 2011 at 3:57pm | IP Logged Quote Geno
The code is defined by my readers website http://www.canobd2.com as the following error description....
"Camshaft Position Sensor 'A' Signal Range/Performance"
Anyone ever experience this? It flags this error red as severe/fix now. What does the repair work entail?
Thanks
Knucklehead....
Back to Top View Geno's Profile Search for other posts by Geno
Geno
Posted: Aug 11 2011 at 6:12pm | IP Logged Quote Geno
Well, I found a pic on where the sensors are. See attached image.
If I replace the bad sensor, will it clear the SES?
Has anyone replaced one on a 2005 Frontier Nismo Crew, manual 6 speed tranny? Was it easy or do you have to be tripple jointed?
Need to clear/fix because it needs to get smogged.
Knucklehead....
Posted: Aug 11 2011 at 7:01pm | IP Logged Quote frontierguy
Have never had to replace one yet. Some things to check
first would be: harness and connections, sensor, camshaft,
starter motor, starting circuit check and battery. Might
also want to clean and tighten all engine grounds.
davidjbrady
Posted: Aug 11 2011 at 11:18pm | IP Logged Quote davidjbrady
Wouldn't Nissan be liable for a failed smog test for the first 7 years?
David
08 Frontier CC, 4X4, LWB
Posted: Aug 13 2011 at 7:55pm | IP Logged Quote frontierguy
NO. TW cats are 8/80 along with ECU, not the individual
sensors.
Geno
Posted: Sep 11 2011 at 3:07pm | IP Logged Quote Geno
OK, here's an update. The dealer replaced "Camshaft sensor 'A'". The total cost was $273 (parts labor) + $35 (diagnostic).
All is good and working now.
My extended warranty paid 100% of it.
Now what I meant to mention (but failed to) was that when the SES light came on, it was during a hard acceleration, high RPM. Dunno if that really matters though.
Knucklehead....
