Subject Topic: Coolant gauge for KA24DE Post ReplyPost New Topic
captflx
Posted: Jun 05 2011 at 1:43pm | IP Logged Quote captflx
Has anyone put an after market coolant temperature gauge for the 4 cyl. engine? The stock sensor /switch for the factory temperature gauge is M12 x 1.25 threads. Where in this world did you find a metric bushing to go to a 1/8NPT after market gauge?
Back to Top View captflx's Profile Search for other posts by captflx
captflx
Posted: Jun 05 2011 at 5:46pm | IP Logged Quote captflx
I might have found it. I'm going to try an oil plug adapter for an oil sending unit with 1/8 npt. I considerit expensive at $20. including freight but if it works, that will be less than a water hose adapter for which I'd have to cut my hose in half.
