Posted: Feb 21 2011 at 6:33pm | IP Logged
2005 Frontier 2WD
In 2008 I replaced my blower motor and resistor. A few months ago I started to have the same problem as before...fan only worked on #4 setting. This time I didn't fix it right away. As a consequence it affected more than just the motor and resistor.
Last week I decided to fix the problem. I bought and installed a new blower motor, resistor, and two fuses that had blown this time around. The two fuses were located in the fuse box in the engine compartment (positions 24 and 27). I checked the A/C fuse in the passenger compartment and that tested okay. I still only have the heat working on #4. I went through the service manual step by step to diagnose the problem. I have used a multi-meter and determined the motor and resistor are both good, the front blower switch is good, and there is continuity between the front blower motor connector and the front blower motor resistor connector.
I don't know what else to check for. Any ideas?? I don't know much else about circuitry other than what I've mentioned above but I am willing to take apart as much of the truck as I can to test things.
