Am4wag Groupie
Posted: Jan 18 2011 at 5:58am | IP Logged
Got a grind in 3rd. gear (only),about 90% of the time.The shifter feels a bit sloppy (from my recollection of asian manuals),but I'm kind of anticipating a synchronizer worn.When removing the trans.,can it be removed from the clutch housing or is it better/easier to remove clutch housing/trans. from engine?Also,are there any specs. or checks I can do in hopes it's just a sloppy "gate" problem?
