Subject Topic: 07 nismo frontier will not start Post ReplyPost New Topic
NorthrnManitoba
Canada
Posted: Nov 22 2010 at 8:36am | IP Logged Quote NorthrnManitoba
i have a brand new fuel pump and when i go to start truck it will turn over and everything but will not fire! seems like a bad relay that controls the fuel pump or something. i am not getting a check engine light so i cannot get a code to show up. any ideas???
Back to Top View NorthrnManitoba's Profile Search for other posts by NorthrnManitoba
NorthrnManitoba
Canada
Posted: Nov 22 2010 at 10:48am | IP Logged Quote NorthrnManitoba
ok sounds like i either have a bad ipdm e/r or a bad ecu relay on the idpm e/r does anyone know where to find the 2007 nissan frontier nismo wiring/idpm layout
 i would like to switch out my ecu realay for my fog light realay for the time being to get by i hear this will work! any info greatly appreiciated
Posted: Nov 22 2010 at 7:49pm | IP Logged Quote frontierguy
Google IPDM E/R and Titanspot will come up. There are a lot
of good pictures and info to lead you in the right
direction.
bmi1965
Posted: Nov 23 2010 at 2:24pm | IP Logged Quote bmi1965
I am having a similar issue with my 2007 SE. intermittently will not fire when i go to start it, usually in the morning or after sitting at work for 8 hrs. takes me anywhere from 1-5 tries before it will fire. turns over with no problem. Sounds like an ECU issue. I found the fuse box thanks to the Titanspot link posted in this thread. I am assuming the titana nd fromntier IPDM box is the same config, so i can pull the fog light relay to slave in for the ECU relay?
Back to Top View bmi1965's Profile Search for other posts by bmi1965
Posted: Nov 23 2010 at 7:58pm | IP Logged Quote frontierguy
bmi1965 Yes -same IPDM E/R
JFoster
Posted: Nov 27 2010 at 8:32pm | IP Logged Quote JFoster
This just recently happened to me I was really worried but it turns out to not be a big deal so far. After reading and researching it a bit the question is do I replace the whole IPDM or just the EMC relay because the fog light one is really just a temporary fix because it does not have the diode in it to protect from voltage spikes.
Back to Top View JFoster's Profile Search for other posts by JFoster
NorthrnManitoba
Canada
Posted: Dec 02 2010 at 10:20am | IP Logged Quote NorthrnManitoba
bmi and j foster same with me seems like wont start after sitting in cold while at work for 8 hours  so i changed the 2 relays and it started up when i got home i checked all my relays   all were good even my old ecu relay that i had switched to fog light spot  so i switched them back to how they were normally and truck started right up and has strated everytime now since i have not had it act up again so if the relay was not bad i dunno why it seems to be working now .  i dunno what else to try but at least truck is running good for now!!! post if u guys figure anything else out
bmi1965
Posted: May 15 2011 at 12:53am | IP Logged Quote bmi1965
I bought a couple of ECU relays and changed it out but did not seem to help. Extremely intermittent. Will go away for a few weeks and then do it every day or every other day for weeks. Thinking it is the IPDM board itself. I am going to check a pick-a-part locally and see if they have one. Anyone know where I can get a new board if the used one does not work?
NorthrnManitoba
Canada
Posted: Sep 23 2011 at 7:51am | IP Logged Quote NorthrnManitoba
just an update since i havent posted for a long time
we just went through summer here and i did not have a starting problem all summer long so i can confidently say that my occasional  starting problem  will only happen due to extremely cold temperatures, in my case anyway!   any ideas appreciated thx
greywarden
Posted: Oct 06 2011 at 1:01am | IP Logged Quote greywarden
i think this case only happens if you are not religiously warming up your car or you often use it. this also happened to me i think 3 times this year but i did not even attempted to check the ecu relays. i just jumpstart my battery and everything went fine. when this is happening to me it really gets me worried because it may cause me to change battery, starter, etc etc. good thing mine is just a minor solution without having a need to buy nissan parts again.
work like there is no tomorrow. No money, No honey.
Back to Top View greywarden's Profile Search for other posts by greywarden
Page of 2 Next >>
