Posted: Feb 17 2006 at 7:26am | IP Logged
Good Day,
As a newby to performance mods, I require some advise on the fitting of a performance cold air inlet system.
I understand the basics but on the stock inlet system there is a rubber pipe mounted on the left of the engine (see photo KA24DE) and this is then connected after the stock air filter, is this only a breather pipe or is it some sort of air temp/flow sensor since there will be no connection for this pipe once the new short ram system is installed.
Regards
__________________ SA HardBody
Hakuna Matata - No Worries!
