Subject Topic: leaking antifreeze Post ReplyPost New Topic
Geckodude18
U.S. - Colorado
Posted: Sep 02 2010 at 9:05pm | IP Logged Quote Geckodude18
I was doing an oil change today. I took off the skid plate and I seen a lot of dried up
antifreeze. I look around to see where it was coming from and found it was coming from accelerator area.
here is some pictures of what I found.
I have no clue what that thing does and why it has antifreeze coming from it. The only thing
I can think of is that it controls the idle after the engine warms up.
So my question is:
1.) has this happen to any of you guys?
2.) is it easy to fix?
2002 Nissan Frontier
King Cab SE
V6 3.3L Automatic 4x4
Back to Top View Geckodude18's Profile Search for other posts by Geckodude18
Posted: Sep 03 2010 at 8:20pm | IP Logged Quote frontierguy
It is actually called a wax pellet assy to control the FAST idle. It is removable and you can replace the "o"ring.PS nice pictures!
Geckodude18
U.S. - Colorado
Posted: Sep 04 2010 at 3:49pm | IP Logged Quote Geckodude18
I thought it was for the idle.  So how easy is it to remove?  Do you just remove the pin that is on the wax pellet?
as for the pictures I just stuck my phone over there really fast so I could post what I was talking about.  My phone does take ok pics.
King Cab SE
Posted: Sep 06 2010 at 5:15pm | IP Logged Quote frontierguy
It is easiest to do if you remove the throttle assy, but not necessary. There is a screw that holds the retainer plate, then carefully pry the assy out of the throttle assy.
