Posted: Apr 04 2005 at 1:46pm | IP Logged
Welcome Aboard Greasemonkey!
Note: Please do not use all cap locks when typing/posting a message in the forums. This topic also would of been better suited if posted in the "Problems / Technical " forum of the board.
Thank You!
As for your speedometer issue, what year and model is your truck. It maybe as simple as only a loose cable connection or the speedometer cable may of become worn out, damaged or frayed which could be causing the speedometer to jump around as well.
