Subject Topic: my alarm goes off on own??? Post ReplyPost New Topic
zillatucker
U.S. - New York
Posted: Jan 19 2010 at 8:50pm | IP Logged Quote zillatucker
my alarm goes off on itz own about 20 mins. after setting...what is the problem...anyone know how to fix this???can i pull a fuse to disconnect it...or is it something i can easily fix...
thanx...
Eric
Back to Top View zillatucker's Profile Search for other posts by zillatucker
zillatucker
U.S. - New York
Posted: Jan 19 2010 at 8:54pm | IP Logged Quote zillatucker
its a 2003 nissan frontier...
Posted: Jan 20 2010 at 5:50pm | IP Logged Quote frontierguy
Pull the battery out of the FOB to eliminate the possibility of one of them screwing up. Make sure all the doors close tightly(with the doors closed, pull out on the bottom rear corner and see if the dome light comes on,this will indicate that the door isn't closing tight enough if the dome light comes on). Unplug the hood switch if equipped.
