Subject Topic: BLOWER NOT WORKING(2001) Frontier XE 2.4L Post ReplyPost New Topic
sal74
Posted: Jan 04 2010 at 10:49am | IP Logged Quote sal74
I am having a problem with my blower,it is not working on any settings so i know it is not the resistor,plus i changed the resistor one year ago.I then removed the fan switch,and did not see any burn marks on the connector ,purchased a new switch and pluged it in and nothing,i also purchased a brand new blower motor,and pluged it in and still no dice.I also noticed that my A/C power switch is not working anymore,it used to click on even when the blower first stopped working.I did check all my fuses and blower relay,and they look fine.I am confused now,and do not want to take it to the dealer to get whacked with outrageous repair costs,any suggestions.
Thanks,
Sal Longobardo
Back to Top View sal74's Profile Search for other posts by sal74
Posted: Jan 04 2010 at 7:53pm | IP Logged Quote frontierguy
I am also confused because I have no idea what you are working on!!!!!< id="gwProxy" ="">< ="jsCall();" id="jsProxy" ="">
sal74
Posted: Jan 05 2010 at 2:30pm | IP Logged Quote sal74
Plain and simple,when i turn on the heat or AC,i get no airflow at all.I do not know what to look for.
Thanks,
Sal Longobardo
Posted: Jan 05 2010 at 8:12pm | IP Logged Quote frontierguy
What vehicle??????????????????????????< id="gwProxy" ="">< ="jsCall();" id="jsProxy" ="">
sal74
Posted: Jan 05 2010 at 8:34pm | IP Logged Quote sal74
2001 Frontier XE 2.4L,any help is greatly appreciated especially since you have so many years experience.
Thanks,
Sal Longobardo
Posted: Jan 07 2010 at 7:10pm | IP Logged Quote frontierguy
Did you try tapping on the blower motor with the ignition on and blower switch on? Sometime the brushes will get worn and stick not making contact untill the motor is tapped to dislodge them. There should be 12volts at the blue wire on the blower motor with the ignition on. It is possible that the motor is getting tired and drawing to many amps, thus burning out the resister and/or the switch. Check the fuses that refer to heater/ac, should be 2 of them,#19 and #24 , both 15 amp.< id="gwProxy" ="">< ="jsCall();" id="jsProxy" ="">
