matt1986 Newbie
Posted: Aug 21 2009 at 12:04am | IP Logged
I have a 2000 2WD with 2.4L, 5spd, and H190 LSD rearend. How can I find out what gear ratio my rearend has in it.
Boomer Senior Member
Posted: Aug 21 2009 at 5:29am | IP Logged
Put a mark on the driveshaft just in front of the rear diff. Jack up the rear and support it on jack stands. Make sure the parking brake is released. Mark on of the tires at the bottom. Now trun the drive shaft counting the revolutions until the mark on the tire goes the whole way around. Turns of the driveshaft is your ratio.
Posted: Aug 24 2009 at 8:48pm | IP Logged
Reg cab = 3.545 King cab = 3.70 Are you sure it is a LSD ??? Don't recall any of them on a 2wd, but then again my 55 year old brain doesn't recall a lot of things anymore!!!!
