| Posted: Dec 10 2005 at 1:26am | IP Logged
chastings92;
I also have a 1999 Nissan Frontier 4X4 V-6 with an Automatic Transmisson. Have you tried changing the Tranny fluid yet? I don't have a lot of miles on mine yet but I drained and refilled mine at 30,000 miles. I also installed an aftermarket cooler... Here are a couple of tips I copied from the Internet:
Drain it then carefully measure how much came out and replace with the exact same amount.. its pretty easy.
You can also do several drain and fills of the pan to get mostly new ATF in there. 4 drain and fills will get you to about 90% new ATF since each drain is 4qts and the total capacity is 8.75-9qts. Then just drain the pan every other oil change to keep the fluid in good shape.
Watch out for the pan bolts, spec is only around 4ft/lbs and they are easy to snap and crossthread.
Have a good one ;) and CUL.. lakota
