Posted: Jul 26 2009 at 2:54pm | IP Logged
Just buy the tie down clips that bolt into the holes you will find in each corner of the bed. I have Utilitrak but bought these and installed them as well. Work great and since I put them in with LocTite, they are permanent. I bought them from Courtesy Nissan.
If you use these, MAKE SURE TO CHASE THE THREADS in the bed walls as they will have the spray in bed liner stuff in them and you'll snap off the bolts if you don't do that before installing the bolts.
