osccean23 Newbie
Posted: May 03 2009 at 2:31pm | IP Logged
am i suppose to put oil in the sc i have notice 5 star bolt on the front face ot the charger right side of top pulley facing the engine talked to dealer in vegas he says no. any suggestions .....
__________________ riding ridin
Posted: Jun 16 2009 at 11:26am | IP Logged
There is a recommended interval to changing the oil in the Super Charger. Exactly what that is should be in the owner's manual. A dealership that tells you that you don't need to change oil in the S/C is one waiting for it to seize up and get more money out of you.
Posted: Jun 27 2009 at 9:04pm | IP Logged
Checked the service manual - does not mention any service for the super charger. I've had them off before, never noticed any place for oil.
osccean23 Newbie
Posted: Jun 28 2009 at 3:27pm | IP Logged
are you saying that five star bolt by the sc puuley is not oil fill line ? i was going to take it off see if it is , just wannna make sure before i do that gonna talk to different dealer in town.
Posted: Jul 08 2009 at 9:17pm | IP Logged
osccean23 wrote:
are you saying that five star bolt by the sc puuley is not oil fill line ? i was going to take it off see if it is , just wannna make sure before i do that gonna talk to different dealer in town. |
No mention of it in the service manual.
Posted: Jul 22 2009 at 8:29pm | IP Logged
2002 Nissan-Datsun Truck Frontier SC Crew Cab 4WD V6-3.3L SC (VG33ER)
Fluid Type Specifications |
Notes |
Information not provided by the manufacturer.
<link rel="stylesheet" href="http://www.alldatapro.com/css/onlineApp2.css" type="text/css" target="_blank">
osccean23 Newbie
Posted: Jul 29 2009 at 11:30am | IP Logged
well idid unsrew the 5 star bolt on the sc it appears to be full and that
oil does stick to your for a while , i believe it takes special oil and nisan doesnt sell it
ergomoto Newbie
Online Status: Offline Posts: 26
Posted: Mar 06 2010 at 2:20pm | IP Logged
This is an old thread now, but still topical even critical for the now few of us still sportin' S/C Frontiers, so I'm posting the obvious to some, if not all now, response to bolster information regarding our Eaton M62 superchargers at this forum.
Yes, the small Torx plug, just to the left of the pulley stalk while standing in front of the truck looking in, is the fill/drain port. It's also the fill mark and the front nose cone that it supports uses nearly all of the 8oz GM Supercharger oil that is available for these units. This specialty oil can be purchased from many super/tubo charger specialty shops including Pulley Boyz.
Torx Drain/Fill Plug Port
One could purchase a syringe necessary to remove the old oil, but I have seen others have done quite well with re-purposed spray bottle nozzles dipping the pick-up tube deep into the port. I've found no mention of the useful life of this oil and prescribed change interval, but one would suspect it would eventually degrade and be of little use, especially if you were to say bolt up a reduced S/C pulley on a now 7 or 8 year old truck with over 80,000.
Best, Mark S
__________________ 1965 Datsun 1300 520 Pickup
2003 Nissan Frontier S/C SE Crew Cab Std Bed
Is that what you wanted it to look like?
