Subject Topic: Aggressice Mud tires for 99 frontier???? Post ReplyPost New Topic
Bear
U.S. - Mississippi
Posted: Sep 07 2008 at 6:03pm | IP Logged Quote Bear
I am looking for some aggressive tires for a 15x7 nissan rim. It goes on a 99 nissan 4x4 standard.   What is max size i can put on stock suspension? Or type of tire? Link or tire names would be appreciated. Thanks-- BeAr
Back to Top View Bear's Profile Search for other posts by Bear
Posted: Sep 08 2008 at 1:40pm | IP Logged Quote kcidmil
I believe a 31" is the biggest you can go on a stock suspension...  Don't qoute me on that though.
How aggressive are you looking to go?  Because you can get everything from a All Terrian to some completely hardcore offroaders.  And those do everything from mud specific, to rock crawling, trails, and sand.
Posted: Sep 08 2008 at 5:04pm | IP Logged Quote lakota
Bear;
I run BFG ATs 31x10.50x 15. You can get a good deal at Costco. I cranked the torsion bars for a 5/8th inch in front and one inch lift blocks from Pep Boys in the rear. You need more clearance for the rear when off-roading a pick up truck. I removed the bumper for even more clearance and assembled a class three hitch to protect the rear sheet metal.
Large tires will screw up your 4x4 crawl ratio.
