Subject Topic: fueling problems Post ReplyPost New Topic
goodhors
Posted: Sep 05 2008 at 12:13pm | IP Logged Quote goodhors
Unable to refuel without gas burping out of tank, must use intermitant squeezes on gas nozel to slowly get gas in tank. replaced suggested servo of exterior tank valve but it didn't help. Any suggestions to solve my venting problem?
Back to Top View goodhors's Profile Search for other posts by goodhors
cartcrazyman
Posted: Sep 10 2008 at 12:33pm | IP Logged Quote cartcrazyman
I also had this problem with my 2001 4X4. Took to dealer tried a couple things, no luck. Dealer contacted Nissan, there fix was to swap out fuel tank. The tube in the tank somehow develops a kink. Can't replace tube by itself. No recall on this. Should be due to gas spilling every time you fill up. After tank swap no more spilling. Cost....$700.
Back to Top View cartcrazyman's Profile Search for other posts by cartcrazyman
goodhors
Posted: Sep 10 2008 at 1:29pm | IP Logged Quote goodhors
ouch....
hopefully there is a DIY fix out there somewhere short of replacing tank.
Posted: Sep 10 2008 at 8:21pm | IP Logged Quote frontierguy
Which vehicle??????????????????????????
cartcrazyman
Posted: Sep 11 2008 at 9:10am | IP Logged Quote cartcrazyman
2001 Frontier. I hope there is one out there now too. If you can do the tank swap yourself it will save you cash. It has been about 1 year and still fixed.
goodhors
Posted: Sep 12 2008 at 8:50am | IP Logged Quote goodhors
The fueling problem is with  a 2004 Desert Runner 2wd frontier 6 cyl
