Subject Topic: A/C Post ReplyPost New Topic
buddyepa
U.S. - Georgia
Posted: Sep 04 2008 at 12:45pm | IP Logged Quote buddyepa
I have a 2004 Frontier, 37K miles and out od warrenty. It has been hot here in GA. In the afternoons, when the A/C compressor kicks in at hwy speeds, I hear a "chirp" like the belt slips as the compressor starts to turn.
What to do if anything?
Back to Top View buddyepa's Profile Search for other posts by buddyepa
Chiefns
Posted: Dec 27 2008 at 10:30am | IP Logged Quote Chiefns
I would have to say it is the belt slipping, even though it's only 37K.
I have 180K miles on my 04 take it from me - when you replace the belts, replace them all at the same time and use NISSAN belts.  Made a mistake once going to pep boys for belt change.
Back to Top View Chiefns's Profile Search for other posts by Chiefns
buddyepa
U.S. - Georgia
Posted: Dec 27 2008 at 5:29pm | IP Logged Quote buddyepa
Thnaks for the info.
I thought it odd that at 37K (now 40K) it needs a belt, but stuff happens, I suppose.
Boomer
Posted: Dec 28 2008 at 6:36am | IP Logged Quote Boomer
A tip on a squeaky belt.  The belt may be fine but getting just s bit hard on the rib surface.  Take a few SMALL dabs of SILICONE grease (not oil-based grease) and spread them across the ribs with the engine OFF.  Then run the truck.  This will quiet belts and will not cause problems with the rubber in the belt.  SIlicone grease is dielectric grease like you put on spark plug boots and is available at any parts store.
Also, DO NOT put the grease on the smooth side of a ribbed belt.  This can cause tensioner slippage.
2007 Nissan Frontier SE 4X4
buddyepa
U.S. - Georgia
Posted: Dec 29 2008 at 6:39am | IP Logged Quote buddyepa
Silicone grease. I will try that, thanks.
