Frontier Towing / Hauling
Subject Topic: 08 fontier tow capacity? Post ReplyPost New Topic
kyimba
Posted: Aug 04 2008 at 9:12pm | IP Logged Quote kyimba
I am trading in my Xterre for a 08 Frontier Auto/6 cly/ 4X4.
The tow rating states 6100lbs. is this true?
I plan to tow 2 snowmobiles in a enclosed tralier.
Trailer would be 17ft at 4500lbs and both snowmobiles would equal 1000lbs.
Will I have problems? Want to know before I sign my name on dotted line.
Back to Top View kyimba's Profile Search for other posts by kyimba
dannyg
Posted: Aug 06 2008 at 12:04pm | IP Logged Quote dannyg
Dannyg here. Now I`ve had 7000pound behind my 06 give your self some extra braking room and have the OD OFFif you get into some stop and go traffic go in 3rd its fine up to about 40mph just to give a little better braking also find out what gear you have thats on the driver side door mine was a CA number your dealerships shop man can tell u what rear u have do`nt liseten to the salesmen he will tell u what ener u want to hear 2.93,3.15.3.73 are some of the ratios my truck has the 2.93 gear BTW how often are going to tow this much weight LT tire might be soming down the road your call. air your stock tire 2-4 psi for towing
06 frontier 4.0 auto
kyimba
Posted: Aug 06 2008 at 3:06pm | IP Logged Quote kyimba
not to sound or look silly, but what does the gear ratio do?
"what gear you have thats on the driver side door mine was a CA number your dealerships shop man can tell u what rear u have do`nt liseten to the salesmen he will tell u what ener u want to hear 2.93,3.15.3.73 are some of the ratios my truck has the 2.93 gear"
I will check with service desk.
Would tow snowmobiles dependent on snow storms at least 6 times a season. Other wise it would be 3 Atvs and that could be a 1 -2 dozen times. Surprisingly I would use my Frontier as a truck, it will be off road, see mud, coal dirt,etc.
Did you tow in mountain regions? I live in Northeast Pa so I am concerned with the inclines
I had a 88 or 89 Nissan pickup (dual 4 cyl) that I LOVED! The only truck that would beat me on dirt piles was a TOY.
any aftermarket items i should look into getting to aid with towing?
dannyg
Posted: Aug 06 2008 at 4:19pm | IP Logged Quote dannyg
danny here dependig gear can help enginge braking having the motor slow you down and for get up and go Example a 3.73 will keep engine revs up a bit higher than my 2.93 and when you back off the gas the 3.73 geared truck will down sooner than my 2.93 when you back of the gas the 3.73 will give you a boogie feeling leaving a stop light. No I do not live in the moutains I`m a florida boy. A lot of people on the site like Banks and Magnaflow cat backs look into the profomance and tech section for upgrades my truck is stock now and it will blow the doors of a TRD tacoma stock to stock
