Posted: Aug 06 2008 at 8:35am | IP Logged
Usually, even if the lock is an automatic lock, it relies on a motor and mechanical arm to lock/unlock the latch.
If you've got a frontier, why haven't you downloaded the factory service manual yet? there's a stick for it in this forum. Here's the link.
http://phatg20.info/index.php?option=com_remository&Item id=26&func=select&id=1
Go there, get your FSM, look up the diagram on the door panel removal and lock diagram.
Hope that helps.
__________________ 2000 Nissan Fronter Crewcab
V6 3.3L
Solar Yellow - the only way to fly.
