Posted: Jun 23 2008 at 5:43pm | IP Logged
bmoore85
Good advice from Boomer!
You should also try moving the front tires to the rear and note if there is a differents.
I had tires that acted like you discribe.
The tires could be improperly balanced, damaged or out of round.
... I bought a set of tires at 4W Parts in Ft.Worth and after four tries they were un able to balance the tires and the replacement tires was just as bad. I took my Frontier to another shop and they balanced the tires perfectly the first try. 4W Parts sold me defective tires that were 3.5 oz out of balance and would only replace them with other defective tires!
I ended up buying a good ones at Costco.
Why did the U.S Government remove food and fuel from the inflation rate?... It sounds better at 4% … I think some of us know better!…
