Nismofrntr Groupie
Posted: Apr 19 2008 at 6:17pm | IP Logged
Does anyone know of a way to make it so the foglights can be on without the headlights being on? i may get a book and read the wire diagram but i didnt know if anyone else has done this.
__________________ 2008 Frontier CC Nismo 4x4
Banks Monster Exhaust
K&N 63 series Highflow Intake
thedave360 Senior Member
Posted: Apr 20 2008 at 1:14am | IP Logged
You could run your own wire harness to them. Just cut the wires from the back of the lights, run a power, run a ground and connect them to a separate switch in the cab. I think that would be the easiest solution. I guess with the stock wires you cut off the lights you could just connect them together to keep them from grounding and sparking.
Baton Rouge, LA
'04 Frontier XE
2.4L 5speed
***MODS***
Flowmaster 40 Series Exhaust
APC Air Intake
Red Calipers & drums
4 Kenwood Speakers
Nismofrntr Groupie
Posted: Apr 20 2008 at 3:31pm | IP Logged
well the more i think about it if its wired the way i think heres what i can do....the relay for the foglamps wont get power until the headlights are on....sooo swap the hot from the headlights with a hot from the parkinglamps....and then the relay has power when the parkinglights are on. I just need to get a wirediagram to see if it is infact wired that way.
Posted: Apr 20 2008 at 6:06pm | IP Logged
I try not to mess with relays and I wouldn't suggest messing with the relay. I worked with a relay when I put some fog lights on my truck. It looked like I had it right, but I hooked it up wrong and I think I "blew" the relay (if thats even possible), because no matter how I hooked it up...it never worked. I just removed it and put a fuse on the circuit and now the lights work.
I would really advise against "rewiring" the relay because if you break it (and/or anything connected to it) the warranty would be void and you would be out of pocket for repairs.
Baton Rouge, LA
'04 Frontier XE
2.4L 5speed
***MODS***
APC Air Intake
4 Kenwood Speakers
Nismofrntr Groupie
Posted: Apr 20 2008 at 9:36pm | IP Logged
good point i didnt think about that
