Frontier Towing / Hauling
Subject Topic: installing trailer hitch Post ReplyPost New Topic
allenh
Posted: Feb 08 2008 at 3:00pm | IP Logged Quote allenh
Has anyone installed their own hitch (w/ electrical connection)?  I'm considering it, but I'm not a gear head...i.e. I can change a tire, change the oil if I really want to, maybe replace the headlights but anything much more detailed than that and I go to the shop.
Back to Top View allenh's Profile Search for other posts by allenh
Hootor
U.S. - Arkansas
Posted: Mar 20 2008 at 12:22pm | IP Logged Quote Hootor
Just installed a hitch bought from Uhaul for $140.00 on my 2004 Frontier. Got the electrical hook-up kit from Nothern Tools. The Hitch was pretty much bolt on, I have the c-channel frame so had to drill one 1/2 hole on each side of lower frame.
The light kit made the electrical part real easy, just unplug the existing connector and plug in the two ends of the plug kit. It cost about $34.00.
Back to Top View Hootor's Profile Search for other posts by Hootor
duckster
U.S. - North Carolina
Posted: Jun 23 2008 at 7:44pm | IP Logged Quote duckster
Hidden Hitch require no drilling I order a hitch off the internet
Back to Top View duckster's Profile Search for other posts by duckster
sailor_lou
U.S. - Connecticut
Posted: Jun 27 2008 at 11:55am | IP Logged Quote sailor_lou
The Nissan receiver was extremely simple, but I would imagine they all would be about the same.   Line it up on the frame and tighten/torque the six bolts.  I also purchased the Nissan light kit, which comes with all the connectors and three relays that you install behind the passenger side kick panel.  Instructions and all the hardware is included.  Pretty easy job, good luck.
Lou
08 Frontire KC, NISMO, 6 speed, Majstic Blue
Back to Top View sailor_lou's Profile Search for other posts by sailor_lou
