Subject Topic: Performance Lifts Post ReplyPost New Topic
trevorg8
Posted: Jan 16 2008 at 7:58pm | IP Logged Quote trevorg8
Suprised that every where i look on this forum i dont see anything about lift kits. I looked at the Calmini five incher but its a drop bracket system which has limitations.
I notice Total Chaos makes a A Arm that will give more travel and give a little more lift, used in conjunction with coil over system by Rancho am expecting at least 3 inches of lift front end but with more travel than a drop bracket system.
Rear i am looking at a shackle kit with add leaf and longer shocks to get 3 inches in the back.
has anyone installed a mid travel suspension kit, or even the calmini lift system. Would like some input from others and i have not seen anything.
NISMO 4X4 Frontier 05
Banks Monster Flow
Volant CAI
Back to Top View trevorg8's Profile Search for other posts by trevorg8
offroading
Posted: Jan 27 2008 at 12:49pm | IP Logged Quote offroading
hey there im looking for a lift 2 and calmini is a great brand but i dont have that cash to lift my truck 5" in the air. im not into rancho's but if thats what u want go for it i guess there not but. i was thinking of spacer and block by calmini and change my upper control arm i dont go alot off raoding but once and awhile but i like the looks.
build it right and ride it right
Back to Top View offroading's Profile Search for other posts by offroading
Posted: Jan 27 2008 at 2:49pm | IP Logged Quote lakota
trevorg8;
Welcome to the group!... See if any of these will work.
Topic Starter Replies Views Last Post
Sticky Topic Topic Admin 4x4 Parts and kits
Pages 1 2 3 4
kcidmil 34 10502 Jan 27 2008 at 1:23pm
By offroading View Last Post
Hot Topic no new posts Topic Admin Suspension lifts
Pages 1 2
americanvtwin 10 2273 Feb 11 2007 at 12:37pm
By XEFrontier05 View Last Post
Hot Topic no new posts Topic Admin 4L 2wd lift kits tigmaned 4 225 Nov 06 2006 at 2:43pm
By hintonl View Last Post
Have a good New Year while you can still laugh about it.. Don S..
Laws such as the use of corn ethanol are driving up the cost of living (have you been to the grocery store lately) without driving up wages. This equates to a lower standard of living thanks to Agro-lobbyists and corrupt and ill-informed lawmakers
trevorg8
Posted: Jan 29 2008 at 8:05pm | IP Logged Quote trevorg8
Ok,
.SoCal Super Trucks has order a A Arm from Total Chaos and also a Coil Over system from an performance coil over company that i forgot the name of. Also a leaf pack for the rear and Bilstein LT shocks.
Total cost if $2015 including parts, install and alignment.
Getting 3 inches of lift front end and roughly the same in the back.
Its not much lift, but i wanted a performing lift with more travel opposed to just a drop bracket system that will only gain me more clearance.
I may add the Calmini drop bracket system at a later date. I will have everything installed within the next two- three weeks and will let you guys know how it goes. Will also take some photos.
2005 NISMO 4X4
4" Mid Travel Suspension Kit
Total Chaos A Arms
Radflo Coil Overs
Volant CAI
Banks Monster Exaust
Big Bear Lake CA
Chris6744
Posted: Jan 30 2008 at 1:19pm | IP Logged Quote Chris6744
check fabtech they make a badass 6in lift for 05-08 cc only
trevorg8
Posted: Jan 30 2008 at 4:24pm | IP Logged Quote trevorg8
I will check fab tech out and see what they have, i beleive theres is also a drop bracket system, but it would be nice to fit some bigger tires after i get this mid travel suspension system.
2005 NISMO 4X4
Total Chaos A Arms
Radflo Coil Overs
Volant CAI
Big Bear Lake CA
trevorg8
Posted: Feb 13 2008 at 1:24pm | IP Logged Quote trevorg8
OK everything has just been installed a total lift of 3.5 inches all around. Some fabrication of the front end needed to be done to fit the coil overs from Radflo. but its strong.
Total Chaos A Arms
Radflo Coil Overs
Leaf Pack-Radflo shocks
Thanks to So Cal Super Trucks.com  check them out if you are located in Southern California. Will update you on performance of new setup
2005 NISMO 4X4
Total Chaos A Arms
Radflo Coil Overs
Volant CAI
Big Bear Lake CA
