Posted: Nov 13 2007 at 12:55am | IP Logged
Can't give you installation instructions but I did read thru the manual for my 2004... If you download the 2005 manual, you should be able to follow thru to see what you need.
There's a Daytime Running Light module, which in my case is apparently on the passenger side front wheelwell area inside the engine compartment. I would think that if your wiring harness has the connector for this component, you might be able to plug it in and with maybe a few other connections, it should be good to go. I can't say for sure, but often the wiring harnasses on U.S. models are the same as Canadian models... extra pieces are either connected or not at the factory depending on where the vehicle is going to end up.
__________________ 2004 XE Crewcab 4X4
2002 Hyundai Santa Fe
1993 Volvo 850 GLT
