Subject Topic: will 4x4 rear springs will fit a 4x2 Post ReplyPost New Topic
sid98
Posted: Oct 26 2007 at 2:37pm | IP Logged Quote sid98
Hi folks,
Will 4x4 rear leaf springs fit on a 1998 4x2?
I'm new here but I have had a my 98 4x2 king cab since new. She's a good pickup. Well, after years of good use the rear is sagging..the leaf springs are basically flat when the bed is empty and I do have a cap installed. I figured that replacing the old spring with 4x4 springs will be a cost effective route and also give a little height boost since the 4x4s seem to ride taller.
Whadayathink?..thanks all.
Back to Top View sid98's Profile Search for other posts by sid98
Smitty
Posted: Oct 26 2007 at 7:50pm | IP Logged Quote Smitty
I'm not sure if they would or not. I would almost like to say that they would. My advice would be to find a junkyard or something, and see if they have what your looking for, measure them and go from there.
Also, probably not that much difference between the 2X2 & 4X4 springs. Most 4X4's have blocks/taller shackles/bigger tires that give it that appearance of riding taller.
2005 Frontier LE Crewcab
Whitesboro Texas
Back to Top View Smitty's Profile Search for other posts by Smitty
hintonl
Posted: Oct 26 2007 at 8:51pm | IP Logged Quote hintonl
Springs are not the same 2wd are spring under more arch 4x4 spring over less arch
2K Crew Cab Converted to 4X4
sid98
Posted: Oct 28 2007 at 7:33pm | IP Logged Quote sid98
Thanks for your responses....so I guess it could work if i bolt in the 4x4 springs but in the over arch setup. Will I have to change anything up front? I'll be hitting the junkyards this week. Maybe I can get a good pic before I tear it off the junk car.
More ideas and thoughts welcomed!
hintonl
Posted: Oct 29 2007 at 4:08pm | IP Logged Quote hintonl
The 4x4 springs will not work as a bolt on thing you will have to do a lot of Fab work to make it work then you would need to figure out how your going to lift the front to match
sid98
Posted: Oct 29 2007 at 8:05pm | IP Logged Quote sid98
ahh...now i understand. Thanks for clearing that up. i'll probably go with the add-a-leaf option then.
