Subject Topic: NEED HELP ASAP Post ReplyPost New Topic
bwr3476_ky
U.S. - Kentucky
Posted: Jul 08 2007 at 11:37pm | IP Logged Quote bwr3476_ky
Hi
I just got a 2000 nissan frontier 3.3 in it.well yesterday it was doing great well to day it started dieing when you would stop at a stop light.well now its has a ruff idle and smoking and you can smell gas like it is flooding out.someone said it could be the map censer .
any ideas would help because this is my first nissan
Back to Top View bwr3476_ky's Profile Search for other posts by bwr3476_ky
bwr3476_ky
U.S. - Kentucky
Posted: Jul 09 2007 at 12:18am | IP Logged Quote bwr3476_ky
i also just noticed its blowing water out the  tailpipe what could that be
bwr3476_ky
U.S. - Kentucky
Posted: Jul 09 2007 at 12:49am | IP Logged Quote bwr3476_ky
at idle you can unplug map censer and idles smooth but when you plug it up idels ruff
Posted: Jul 09 2007 at 1:27am | IP Logged Quote lakota
bwr3476_ky;
If the engine and exhaust system are fully warmed up and it still has water coming out it's possible you have a blown head gasket or cracked head. Check the water to see if it looks like it might be antifreeze.
Sorry I can't help with the other problem.
bwr3476_ky
U.S. - Kentucky
Posted: Jul 09 2007 at 2:04am | IP Logged Quote bwr3476_ky
no when truck is warm no water at all
Posted: Jul 10 2007 at 7:34am | IP Logged Quote kcidmil
Sounds like a bad spark plug or spark plug wire to me.
S.A.R.Tech
Oil Tech
Posted: Aug 11 2007 at 11:22pm | IP Logged Quote S.A.R.Tech
any codes?  might be an oxygen sensor too.  If it is coolant, it'll be burning it and that mean LOTS of really white smoke.  There will be no question when it happens.  Oil is blue, fuel is black and coolant is white, sh*t is brown and grass is green.  Maybe anitknock sensor?
firefighters don't need to compensate, they just kick ass
Back to Top View S.A.R.Tech's Profile Search for other posts by S.A.R.Tech
