Posted: Apr 16 2007 at 8:15pm | IP Logged
Young sir I have the answer.
once upon a time I owned a 2004 nissan frontier 4cyl. Much like the one KCIDMIL so proudly displays. Went to a performance shop and had a custom IMCO (international motor company) 2.25" steel exhaust installed. IMCO muffler welded to a steel pipe. This was a bad idea because steel will rust super fast and if your installer can't weld correctly or the grade of metal isn't up to the task then the welds break and you get yourself a wonderful nasting sounding leak. this happened twice.
You can have a flowmaster muffler welded to a pipe but it could still break. Allow me to recommend a STAINLESS steel BOLT on exhaust system that attaches to your factory brackets. This requires no welding, bending, or the risk of cracks, not to mention rust! Want one? www.4x4parts.com under performance. Only thing is it costs like $500. dude they are superior and you wont go wrong w/ it. Why go w/ a lame steel exhaust when your truck ALREADY comes w/ a smaller diameter stainless one?
Got rid of my 04 front after going through 3 transmissions with in 38,000 miles. Went back to the dealer and complained, they gave me an 07 XE. So far no problems! and for the record my friend, our trucks only have 154hp and 171torque. They are slow, but economical. Now somebody out there needs to design an INTAKE for the XE 05-07 frontier!!!!!!!
good luck
__________________ benjamin
