Subject Topic: Crankshaft Position sensor Post ReplyPost New Topic
brian
U.S. - North Carolina
Posted: Apr 06 2007 at 6:15pm | IP Logged Quote brian
Hello,
 I have a 2000 Nissan Frontier crew cab with a 3.3L engine/5 speed transmission.  I need to replace the sensor, but I can't find it!  Please HELP!  Book said it is located at the back of the engine on the bell housing.  I looked everywhere with no luck in finding it's location.  IF you know of a website or where it's located I'd appreciate some help.
Thanks,
Brian
Back to Top View brian's Profile Search for other posts by brian
shadow0289
Posted: Apr 28 2007 at 10:13pm | IP Logged Quote shadow0289
on the driver side. a 10mm head bolt holds in a cover and the sensor. Its on the driver side. If you lift the liner its on the bell of the transmission right before you get to the top bolt for the tranny to engine.
Back to Top View shadow0289's Profile Search for other posts by shadow0289
