Subject Topic: Cracked Exhaust Manifold Post ReplyPost New Topic
The Vex
U.S. - Connecticut
Posted: Mar 28 2007 at 3:54pm | IP Logged Quote The Vex
Hi Everyone!
I am a first time poster to a Nissan forum and had a question for the resident experts (or anyone in the know). My exhaust manifold in my 1998 Frontier cracked, and I've been trying to locate a new one. Problem being, it's the California Emissions manifold and therefore $900 to replace. I was wondering if you knew of any cheaper way to fix my particular problem, perhaps if a swapover is more effective (i live in Connecticut).
Any ideas would be helpful to me.
Thanks,
John
Back to Top View The Vex's Profile Search for other posts by The Vex
Posted: Mar 28 2007 at 6:43pm | IP Logged Quote kcidmil
If smog testing isn't an issue for you.  I would look into aftermarket headers.  This will help the engine exhale better, as well as being a cheaper alternative than buying a manifold from the "Stealership"
The Vex
U.S. - Connecticut
Posted: Mar 28 2007 at 8:43pm | IP Logged Quote The Vex
The thing Im wondering about is possibly having to reconfigure the computer, or causing it to function poorly because of a swapover. If I have to get a California emission manifold, does anyone know a cheap place to get one?
ttrimaldi
Posted: May 07 2007 at 10:22pm | IP Logged Quote ttrimaldi
Exhaust manifolds can be welded depending on where the crack is.  I've seen it done on tractors with gas and diesels for years.
Tony
Back to Top View ttrimaldi's Profile Search for other posts by ttrimaldi
wags351
U.S. - New Mexico
Posted: May 22 2007 at 10:25pm | IP Logged Quote wags351
Hey I have the same exact PROBLEM!!! I just haven't done anything about it.  i've tried ordering a couple different ones but they don't work cause they aren't the california emissions style.  So have you found out what works to fix it yet?  i have a 98 XE, 4x4, 2.4l, 5spd.
Back to Top View wags351's Profile Search for other posts by wags351
