Frontier Towing / Hauling
Subject Topic: Too Heavy??? Post ReplyPost New Topic
DrKwan
Posted: Mar 20 2007 at 5:44pm | IP Logged Quote DrKwan
So I just bought this 2007 LE CC LB and I'm thinking of placing 2 motorcycles (around 500 lbs each) in the bed, driver/passenger combined weight roughly 400 lbs and total gear weight maybe 100 lbs.  I think I'm rated at 1260 lbs, but this will tally up to 1500/1600 lbs.
So what do you think, too much?
My plan is to travel primarily highway around 1200 miles round trip.
Dr. Kwan
Chance favors the prepared mind
Back to Top View DrKwan's Profile Search for other posts by DrKwan
Posted: Mar 20 2007 at 8:37pm | IP Logged Quote kcidmil
The rating usually does not use passengers since it's meant more for the rear end.  I would load everything up and see how it looks.  If most of the gear ends up in the cab, it will help even out the load.
DrKwan
Posted: Mar 21 2007 at 5:21pm | IP Logged Quote DrKwan
Thanks.  I thought the rating included passengers and everything but I'm new to this so I'll give it a try.  Won't happen for a few months; I'll post back then.
DrKwan
Posted: Mar 21 2007 at 6:37pm | IP Logged Quote kcidmil
If you get a lot of sag, you could look into getting assist springs.  They're usually not too much, around $200-$300
DavesNismo17403
Posted: Mar 24 2007 at 6:37am | IP Logged Quote DavesNismo17403
Drkwan, You should not have any problems hauling your bikes.  I tow a 25ft trailer without out any problems and very little sag.  So go out and have fun...
Back to Top View DavesNismo17403's Profile Search for other posts by DavesNismo17403
Frontyfan
Posted: Mar 24 2007 at 7:26pm | IP Logged Quote Frontyfan
I think on www.nissanhelp.com it lists payload rating including passengers, but not certain on that.
'01 SE CC Shortbed silver
ColinThePilot
Posted: Mar 31 2007 at 8:46pm | IP Logged Quote ColinThePilot
I hauled two bikes in my 06KC and it was no problem. its a squeeze to get them both in there, but it works and drives fine.
Back to Top View ColinThePilot's Profile Search for other posts by ColinThePilot
DrKwan
Posted: Apr 02 2007 at 9:32am | IP Logged Quote DrKwan
Thank you people.  That puts my mind at ease a little.  I'll post up some pics if/when the day happens.
