Subject Topic: Exhaust Leak-99 Fronty SE Post ReplyPost New Topic
fishoholic
Canada
Posted: Feb 06 2007 at 11:36am | IP Logged Quote fishoholic
Anyone have problems with broken manifold bolts or gaskets on the passenger side of engine? Leaking somewear by engine scared to pull the heat shields off.
Thanks
If it ain't dirty and in the bush, buy a car!
1999 Fronty SE
Back to Top View fishoholic's Profile Search for other posts by fishoholic
98_F-SER
U.S. - Kentucky
Posted: Feb 07 2007 at 4:17pm | IP Logged Quote 98_F-SER
YES!!! my manifold cracked right down the middle! i opted to replace it with the more affordable pacesetter header which i like. some people say they are not worth the money but if you have to replace the manifold i would strongly suggest it.
Back to Top View 98_F-SER's Profile Search for other posts by 98_F-SER
fishoholic
Canada
Posted: Feb 08 2007 at 9:50am | IP Logged Quote fishoholic
Like i said I'm scared to look at the details come spring, I know the leak is somewhere by the manifold, just hope its something cheap!
Thanks
1999 Fronty SE
Aaron360
U.S. - Mississippi
Posted: Mar 05 2007 at 10:35am | IP Logged Quote Aaron360
What kinda sound is it making because im thinking mine is leaking.. IM geting a ticking sound..
Back to Top View Aaron360's Profile Search for other posts by Aaron360
Johnnyby68
U.S. - New York
Posted: Mar 09 2007 at 5:40pm | IP Logged Quote Johnnyby68
i have the same exact thing in my 2000 CC. i can really hear it when its cold and i don't let it warm up much then take off. i've been told i'm hearing things haha. just gives me a reason to put headers on it.
Back to Top View Johnnyby68's Profile Search for other posts by Johnnyby68
fishoholic
Canada
Posted: Mar 13 2007 at 8:35am | IP Logged Quote fishoholic
Aaron360
If you crank the hood open and listen on both sides of your engine block you should hear a hissing, hit the throttle from under the hood, if theres a leak there, you'll hear it.
1999 Fronty SE
fishoholic
Canada
Posted: Mar 13 2007 at 8:38am | IP Logged Quote fishoholic
Johnnyby68
definetly sounds like the same case as mine, a good way to tell if theres a leak is the same as explained to Aaron360, instead have someone stick there hand over the exhaust without cranking the throttle, this will louden and intensify the leak. should be leaking by the manifold.
1999 Fronty SE
