Subject Topic: Nissan Frontier Advice Post ReplyPost New Topic
LaxGuy1390
Posted: Jan 23 2007 at 9:34pm | IP Logged Quote LaxGuy1390
I just bought a black 2004 Nissan Frontier KC XE 2WD and I was wondering what I should do to raise the body of the truck higher, if possible I would like it 4-6 inches higher should I look into lifts or are there bigger tire sizes for me to do this. This is my first car so I am unsure of what to do. Thanks for any help!
Back to Top View LaxGuy1390's Profile Search for other posts by LaxGuy1390
Joehova
U.S. - Colorado
Posted: Jan 24 2007 at 9:15pm | IP Logged Quote Joehova
You might want to consider a lift and slightly larger tires. I wouldn't recommend a body lift. Check out www.4x4parts.com . There might be a lift on this site that isn't too costly.
---Joe---
05 NISMO 4x4
Back to Top View Joehova's Profile Search for other posts by Joehova
Posted: Jan 24 2007 at 10:08pm | IP Logged Quote kcidmil
Since this is your first vehicle, I wouldn't suggest raising and putting too big of a tire on.  It'll effect your gas mileage, and next thing you know you'll be questioning taking it out because you'll have to put gas in.
Since you want 4-6 inches, definitely suspension lift.  Body lift will give a horrible stilt effect, and you'll be swaying before you know it.
I think a mild lift with slightly larger tires will do just fine.  You won't get your 4-6 inches, but it'll look aggressive.
Joehova
U.S. - Colorado
Posted: Jan 26 2007 at 7:35pm | IP Logged Quote Joehova
Another reason to stay away from body lifts is because they have a tendency to lower the resale value.
---Joe---
05 NISMO 4x4
