TSB - Technical Bulletins
 Nissan Frontier Forums : Problems / Technical : TSB - Technical Bulletins
Subject Topic: Overheat during idle Post ReplyPost New Topic
freddieb
Posted: Aug 28 2009 at 9:45am | IP Logged Quote freddieb
My 2003 frontier 4cyl heats up when idling in traffic in gear and with ac on.  Ok on the highway.  Also noticed transmission pulls rpms down to 400 when this occurs.  fan clutch did not fix.  Could transmission or injectors be the culprit?
freddieb
Back to Top View freddieb's Profile Search for other posts by freddieb
jh3isme
Posted: Oct 17 2009 at 10:01pm | IP Logged Quote jh3isme
Well the first thing i would do is inspect the cooling system and thermistat consider the radiator could be clogged water pump could be faulty. And you could very well have a clogged exhaust system,catalatic converter usually. These are just a few things now the trans mission was not mentioned im assuming its a automatic and I would consider getting the trans flushed and inspected by a perfessional. There are so many trouble shooting opptions that can play in this issue.
!20)@niSSan,
Back to Top View jh3isme's Profile Search for other posts by jh3isme
ttimothyp16
U.S. - New Mexico
Posted: Feb 25 2011 at 6:04pm | IP Logged Quote ttimothyp16
idling is the most common time to overheat because your not
getting any air to engine. turn the heater on to suck hot
air out.
Back to Top View ttimothyp16's Profile Search for other posts by ttimothyp16
