AZLS1 Groupie
Online Status: Offline Posts: 43
Posted: Dec 04 2005 at 3:41pm | IP Logged
I got mine from ebay. I actually bought 2 and planned to double them
up. The install of one was so easy that I ended up only installing the
one.
Here are my install notes:
1. Remove the front grill
- six push tabs mount the top.
- 4 twist clips (2 on each side) mount the sides.
- 2 tabs hold the bottom of the grill to the bumper.
2. Unplug the oem horn.
3. Removed the nut that holds the horn to the mount, and remove the horn.
4. Drill out the mounting hole in the oem bracket so that the new Stebel bolt would fit through the hole.
5. Bolt the new horn in using the hardware provided by Stebel.
6. Plug in the Stebel horn using the existing OEM wiring.
7. Re-install the grill (see notes below) and turn off the beep function for the door lock on the key fob.
Notes~
Twist tabs:
- To remove the grill from the twist tabs holding the side of the
grill, Insert a screw driver into the slots of these tabs and twist 90
degrees and pull the grill forward.
- Prior to re-installing the grill, pinch the tabs on these tabs and
remove them from the truck. Re-insert the tabs into the grill.
Key fob beep function:
- The beep function will not work properly with this horn. If you do
not disable it you will only hear the sound of the horn relay clicking
instead of the horn itself.
Dual horns:
I did not install both horns for the following reasons:
- I was not confident that 2 horns would run properly
on the existing oem wiring.
- I live in Arizona and wondered if the additional horn would disrupt the air flow through the radiator.
- I didn't want to do the additional wiring to run the second horn.
Thoughts:
- The horn is pretty loud, but the frequency is fairly high. It would be nice to have a lower tone horn to go with it.
- No one will mistake it for a train or 18 wheeler horn.
- Pretty nice horn overall.
Good luck and send me a message if you have any additional questions,
Sterling.
iis4isaac Newbie
Posted: Jan 15 2008 at 9:28am | IP Logged
I looked over the online install guide. Don't you need to upgrade the wiring and relay to provide the amount of power this horn needs?
__________________ 2000 Nissan Fronter Crewcab
V6 3.3L
Solar Yellow - the only way to fly.
jers Newbie
Online Status: Offline Posts: 30
Posted: Mar 24 2008 at 1:38pm | IP Logged
Your instructions are great, but where are the install pics?
thedave360 Senior Member
Posted: Mar 25 2008 at 2:52am | IP Logged
I installed some of their horns on my truck. It sounds like you installed something similar to what I have. I was able to install them with out removing my grill, I have a pic in my gallery of where I have them installed. All the wiring was easy to do, Im thinking about upgrading to the Heavy Duty, bus horns.
Baton Rouge, LA
'04 Frontier XE
2.4L 5speed
***MODS***
Flowmaster 40 Series Exhaust
APC Air Intake
Red Calipers & drums
4 Kenwood Speakers
eitydeuce Newbie
Online Status: Offline Posts: 24
Posted: Aug 06 2009 at 12:59am | IP Logged
Hey thedave, you have the same set up as me. Can you tell me where you got all your aftermarket stuff at? such as the air intake because i hate to say it but sometimes i want to put the gas pedal through the floor board. Is there anything i can do to gain just a bit more power?
acroRUSS-D Newbie
Posted: Jan 20 2011 at 10:01pm | IP Logged
good post, dont know if you all have ever heard of Hornblasters, but a friend of mine owns the co. and they have ANYTHING and EVERYTHING you need for all horns. Get in touch with Rigo, and let him know RUSS-D sent ya. He will hook ya up fo sho. http://www.hornblasters.com/products/category.php?c=train-ho rn-kits-and-air-horn-kits&coupons=fs2010111&gclid=CK Tmhva0yqYCFcXD7QodKnubFw
yankeeredneck Newbie
Posted: Apr 17 2011 at 6:34pm | IP Logged
WHERE can I find the electronic horns that an ambulance has?
__________________ 2011 Frontier SV
droopydawg Newbie
Posted: Mar 01 2012 at 4:27pm | IP Logged
I installed a Stelbel Nautilus on my motorcycle, and it required an external relay. You should see the scared looks on soccer moms faces when I lay on the horn when they start to move over on me.
__________________ Drew Mobley
Lake Forest, Illinoying
05 CC SE 4x4 V6 6spd man.
Posted: Mar 01 2012 at 6:22pm | IP Logged
ne1??
