Subject Topic: front suspension squeaking Post ReplyPost New Topic
blackmagicx
Posted: Oct 17 2006 at 8:14pm | IP Logged Quote blackmagicx
grease your upper control arm bushings.  and your bump stops.  and if you'd like add zerk fittings to the upper control arms. that'll fix your problems.
Back to Top View blackmagicx's Profile Search for other posts by blackmagicx
TheRedRocket345
Posted: Oct 30 2006 at 8:04pm | IP Logged Quote TheRedRocket345
ya i have the same problem w/ my 05 frontier. I took it in an found out the squeaking came from the hood apparently the rubber stoppers came loose and once they where tightened, the noise stopped.
Back to Top View TheRedRocket345's Profile Search for other posts by TheRedRocket345 Visit TheRedRocket345's Homepage
Chris
U.S. - Louisiana
Posted: Nov 10 2006 at 7:42am | IP Logged Quote Chris
I noticed the same thing with my o5, after crawling under it and not finding the "squeek" I started under the hood and found the issue/ squeek. On the left of the engine compartment there are two fuse boxes, one large and one small, the smaller of the two was not secure and was in fact where the squeeking noise was comming from
If you always do what you've always did, then you'll always get what you've always got
Back to Top View Chris's Profile Search for other posts by Chris
Chris
U.S. - Louisiana
Posted: Nov 24 2006 at 12:50pm | IP Logged Quote Chris
Regarding the front end squeak, I also found that the hood latch was making the squeak as well, I took mine in for service and after tightening and lubricating the hood latch and repairing the loose fuse box the squeak stopped.
sidclaim
U.S. - Virginia
Posted: Dec 14 2006 at 9:57pm | IP Logged Quote sidclaim
I have 99 frontier 4 cylinder and have front noise like squeak when turning. One problem I have is the front sway bar/stabilizer I-bolts keep getting busted in-half. The two original bolts busted, 2 manufactured bolts busted, plus 2 temporary 3/8 threaded bolts busted. I cost $50 a pair.
Back to Top View sidclaim's Profile Search for other posts by sidclaim
Jackal
Posted: Dec 25 2006 at 11:53am | IP Logged Quote Jackal
I have a '02 frontier 4x4 and had the same problems. It would squeek when getting in and out of it , or when driving slow with the wheels turned right or left ( real tight).
Found out it was the snubbers on the A-arms. A small rubber 1" x1" x 1" rubber piece that limits the  steering from turning too tight and causing damage. It will be on the rear side of the A-arms where you will see a worn spot with the paint gone . I ended up sanding the tips of the rubber and spraying  a dry-black molycote lubricant on the  A-arms . This will stop it for a while and then do it again later.
 JAckal
Back to Top View Jackal's Profile Search for other posts by Jackal
MRJONES944
Posted: Jan 07 2007 at 11:41am | IP Logged Quote MRJONES944
i would bet money that this is the result of damaged or unlubed ball joints.  If you have a scope check the upper ball joints.
Back to Top View MRJONES944's Profile Search for other posts by MRJONES944
JFordBronco
U.S. - Louisiana
Posted: Jan 14 2007 at 1:34am | IP Logged Quote JFordBronco
Well hell, I wish I wold have found this earlier.  My 05 Frontier I took on a Jeep Jamboree Pre-Run here in Louisiana and after the ride the damn thing squeeked.  It still does, Nissan has looked at it and looked at it and hasn't been able to find anything.  Will try these
Joel
2005 Nissan Frontier Nismo - tow rig. 1995 Ford Bronco XL with 6" lift and soon to be 35's and 2007 Yamaha Big Bear both are my play toys.
Back to Top View JFordBronco's Profile Search for other posts by JFordBronco
Bliving1978
Posted: Jan 23 2007 at 9:50am | IP Logged Quote Bliving1978
I have an '04 4x4 crew cab and was hearing the sqeeks for a while. Now, it's much worse... The stabilizer brackets on both of the lower a-arms have sheered off. This left the swaybar hanging to damage the rest of my steering and suspension. I found out each of the a-arms cost about $625 and there aren't any lift kits or suspension systems that replace them...what the heck, anyone else have this issue yet?
Brian
2004 Frontier XE Crew
Back to Top View Bliving1978's Profile Search for other posts by Bliving1978
Posted: Jan 23 2007 at 4:11pm | IP Logged Quote lakota
Welcome to the group to those posting for the first time. None have mentioned shocks yet
... I've only had one squeak from any of the six Nissans we've had/have. It was the a rear shock absorber on our '95 4x4 Hard Body. I squirted oil on the shaft twice and the squeak went away.
Have a good one,    and Carry on.. Don S..
<< Prev Page of 4 Next >>
