Posted: Jan 09 2011 at 4:27pm | IP Logged
They have a memory saver that will plug into the DLC, which
will retain the ECU memory. Most power outlets are only
"hot" with the key "on". So you wouldn't want the key on to
do a disconnect which would keep the power outlet alive
with a memory saver????!!!!???? It all seems so confusing
at times!!!
