Drews04fronty Newbie
Posted: Jul 09 2010 at 9:03am | IP Logged
Iv been searching for a while now and still cannot find anything about how to install the OEM fog lamps that did not come with my 04' crew cab. Any help would be appreciated such as what wires go to what, its pretty much plug n play with the connector pieces, theres a few wires im not sure where i should be running.
davidjbrady Senior Member
Online Status: Offline Posts: 356
Posted: Jul 09 2010 at 10:14am | IP Logged
Nothing came with the lights in terms of instructions?
Posted: Jul 09 2010 at 10:57am | IP Logged
No there were no instructions. all the necessary parts i have just no diagrams or instructions. and guys at nissan are useless
Posted: Jul 09 2010 at 7:16pm | IP Logged
The connectors for the lites should be taped to the harness near the opening for the fog lites. The fog lite switch is part of the head lite switch, correct?? Just remove the existing one and install the new one.
m8kitrun Newbie
Posted: Jul 10 2010 at 1:08am | IP Logged
i am very new to this so you may very well discard my input, but are you wanting your fog lights to be completely "factory"? i just installed fog lamps on my '10 frontier using only the factory lamps themselves and wired them myself so i can turn them on at will and don't have them shut off when i turn on the brights. everything looks "factory" but i have more function. if you are wanting completely "factory" fog lamps then i cant offer much help, but if you are looking for advice to get them working then let me know and i can give you a very easy solution readily available at your local parts store with instructions and all.
Posted: Jul 10 2010 at 4:51pm | IP Logged
KEEP in mind this is for an 04' Frontier
They are factory lights, with a wiring harness, NO SWITCH ON STEERING COLUMN
It is a switch that mounts next to teh steering wheel so i can turn them on when i want.
i just dont have instructions on where to run wires
Posted: Jul 11 2010 at 8:02am | IP Logged
When you say FACTORY, did you purchase them from a Nissan dealer???? A lot of aftermarket use the wording "factory".
The FACTORY fog lite switch is on the headlite/turn signal switch.
Posted: Jul 11 2010 at 9:51am | IP Logged
it is aftermarket, but its exactly the same as factory, same harness and all
Posted: Jul 11 2010 at 7:38pm | IP Logged
If it is aftermarket it is not the same as factory. The fog lite switch is on the same stalk as the headlite switch.
Posted: Jul 12 2010 at 6:28pm | IP Logged
OK so here is a few pictures of what im talking about from the Light all the way to the Switch inside the car. hopefully someone can shed some light on the situation and help me out thanks guys!
