Subject Topic: Engine starts but won’t go over 2k rpms Post ReplyPost New Topic
dmartin16
Posted: Feb 24 2010 at 11:31am | IP Logged Quote dmartin16
Just as I thought it would be. Try taking some break cleaner or carb cleaner to the MAFS and let it dry. That's cleared error codes from mine several times.
Best of luck!
2003 Frontier XE (Base)
Back to Top View dmartin16's Profile Search for other posts by dmartin16
dmartin16
Posted: Feb 24 2010 at 11:37am | IP Logged Quote dmartin16
Also, you can get a remanufactured one with a warranty from Autozone:
____________
That means it's only 140$ if you swap them your old one for the remanufactured one.
I only recommend replacing if the break cleaner/carb cleaner doesn't work.
As always, Best of luck!
Posted: Mar 03 2010 at 6:42pm | IP Logged Quote frontierguy
Don't use carb cleaner on a MAFS, too strong. Brake cleaner is OK followed by gentle air blowing. It seems like I've seen MAFS cleaner in AZ or Advance auto????< id="gwProxy" ="">< ="jsCall();" id="jsProxy" ="">
Jerry23774
Posted: Mar 05 2010 at 12:57pm | IP Logged Quote Jerry23774
I sprayed some mafs cleaner and it didn't fix the problem. It did however rev up past 2rpm after the engine died for a second or so. I'll have to replace the part. I'll try out AutoZone with that refund discount. If this works I'll feel like a real pro. Thanks.
Back to Top View Jerry23774's Profile Search for other posts by Jerry23774
<< Prev Page of 2
