Posted: May 26 2008 at 1:44pm | IP Logged
Checked the fuel pressure and it was on about 40psi at ignition and then dropped to 38 or so steady. Thought the book said 34..while running...
I am able to do the following:
1. Everytime I start the vehicle she sits there and purrs at idle.
2. If I want to push the gas and rev her up I simply push the gas slowly until she gets to 2,500 rpms or so and then I use my thumb to cover the inlet on the MAF hole, about 90% covered. Then while my thumb is covering 90% of the hole I can sit threre and rev her up and down like a race car. Engine soulds good and varoom, varoom.
Then if I want to let her go back to idle I must remove my finger (90% covering the MAF inlet hole on the top of the throttle body) from covering the hole. If I don't the vehicle will stall and shut off as it returns to idle. If I take my finger off after reving her up the truck will drop back to a perfect idle.
Is it the MAF?
Thanks!
Mr. Tripp
Augusta, GA
